# Android App
The openHAB Android application is a native client for openHAB, compatible with phones and tablets. The app follows the basic principles of the other openHAB UIs, like Basic UI, and presents your predefined openHAB sitemap(s) (opens new window).
Get it on Google Play Get it on F-Droid
Demo Overview Widget Overview Google Maps Widget
# Getting Started
On first start the app tries to discover your openHAB server. This will only work on local networks and when the server does not enforce either authentication or HTTPS. If it fails, you can click on Go to settings and manually enter the server settings.
  • IP address: http://192.168.1.3:8080
  • Local hostname: http://openhab:8080 (depending on your network the suffix .local needs to be added to the hostname)
  • Remote domain name: https://myopenhab.org for an openHAB cloud account with myopenHAB (opens new window)
# Features
# Permanent Deployment
If you have more than one device, it's recommended to fill out the device identifier on the main settings page. This prefixes every item name, e.g. with the Prefix John the item AlarmClock becomes JohnAlarmClock. This way you don't have to change every item name.
  • Event based (Alarm clock and call state)
  • Schedule based (Everything else)
# Alarm Clock
The openHAB app will send the next wake-up time from your alarm clock app to the server. The time is sent as a number containing the number of milliseconds since the epoch.
Example item definition:
Example rule:
var Timer timerAlarm = null
rule "Alarm Clock"
    Item AlarmClock changed
    if (newState instanceof DateTimeType) {
        val epoch = newState.toLocaleZone.zonedDateTime.toInstant.toEpochMilli
        logInfo("alarm", "Scheduling alarm for {} ({})", newState.toLocaleZone, epoch)
        if (timerAlarm !== null) {
            logInfo("alarm", "Reschedule alarm")
            timerAlarm.reschedule(newState.toLocaleZone.zonedDateTime)
            logInfo("alarm", "New alarm")
            timerAlarm = createTimer(newState.toLocaleZone.zonedDateTime, [ |
                logInfo("alarm", "Alarm expired")
                timerAlarm = null
            timerAlarm.cancel
            timerAlarm = null
        logInfo("alarm", "Alarm canceled")
# Call State
Example rule:
rule "Call State"
    Item CallState changed
        // No call activity
# Battery Level
Example rule:
rule "Battery level"
    Item BatteryLevel changed
        // Battery level is low
# Charging State
The charging state can be send to a String Item that contains the charger type or to a Switch Item, which is ON when charging, OFF otherwise. The app determines the Item type automatically, so it's not required to configure the Item type in the app.
// or
rule "Charging state"
    Item ChargingState changed
# Wi-Fi Name (SSID)
Example rule:
rule "Wi-Fi name"
    Item WifiName changed
    if (WifiName.state == "UNDEF") {
# DND Mode
Example rule:
rule "DND mode"
    Item DndMode changed
        // DND mode is unknown
# Device identifier
# Tasker Action Plugin
Variables can be selected as state after they have been created in the task. The variable %httpcode is returned by the plugin and contains the HTTP code returned by the server.
Error Code Description
10 Tasker plugin is disabled
11 The app couldn't establish a connection
1000+ A connection was established, but an error occurred. The error code is 1000 + the HTTP code, e.g. 1401 means Unauthenticated (opens new window).
# Multi server support
  • Display Sitemaps and HABPanel
  • Voice commands launched from in-app (sent to active server) and from widgets (sent to primary server)
  • Show a list of recent notifications
  • Sitemap shortcuts on the home screen
  • Shortcuts for HABPanel, notifications and voice command
  • Item widgets on the home screen
  • Quick tiles
  • NFC tags
  • Push notifications
  • Send device information to openHAB
  • Tasker plugin
# Help and Technical Details
  • Notifications are only fetched every 6 hours by default. It uses the same schedule than Send device information to openHAB.
  • Read status aren't synced between devices.
  • The maximum number of messages that can be received during one fetch is limited to 20.
# My voice command rule isn't run
Please make sure that Default Human Language Interpreter is set to Rule-based Interpreter (http://openhab:8080/#!/settings/services/org.openhab.voice (opens new window)) and that the correct Item is selected at Other Services => Rule Voice Interpreter => Voice Command Item (http://openhab:8080/#!/settings/services/org.openhab.rulehli/select/ (opens new window)).
# Chart loading is too slow
Generating charts can be taxing to the server. If you experience slow chart loading times and your server isn't powerful, open Settings and disable High resolution charts to improve loading times.
# Icons look pixelated
# Trademark Disclaimer
