# Sitemaps
In openHAB a collection of Things and Items represent physical or logical objects in the user's home automation setup. Sitemaps are used to select and prepare these elements in order to compose a user-oriented presentation of this setup for various User Interfaces (UIs), including BasicUI, the openHAB app for Android and others.
    Frame label="Date" {
        Text item=Date
    Frame label="Demo" {
        Group item=Heating
        Text item=LR_Multimedia_Summary label="Multimedia [%s]" icon="video" {
            Slider item=LR_TV_Volume
# Concepts
Elements: Sitemaps are composed by arranging various user interface elements. A set of different element types supports a user-friendly and clear presentation. The example above contains Frame, Text and Switch elements among others. Elements present information, allow interaction and are highly configurable based on the system state. One line of Sitemap element definition produces one corresponding UI element. As shown in the example, each element generates a descriptive text next to an icon on the left side and a status and/or interaction elements on the right.
Parameters: A certain set of parameters can be configured to customize the presentation of an element. In the shown example item, label and valuecolor are parameters. Almost all parameters are optional, some are however needed to result in a meaningful user interface. To avoid very long or unstructured lines of element definition, parameters can be broken down to multiple code lines.
Blocks: By encapsulating elements with curly brackets, multiple elements can be nested inside or behind others. The Frame element type is often used in combination with element blocks. Frames are used to visually distinguish multiple elements of the same topic on one interface page. When using code blocks behind other element types such as Text or Group, these UI elements will, in addition to their normal function, be links to a new view, presenting the nested elements. In the above example, multiple Frames are defined and some elements are not visible on the main view but are accessible behind their parent element. These are indicated by the ">" control icon on the right of an element.
Dependencies: A typical sitemap contains dozens of individual elements. A system state and possible interactions are however often closely dependent. openHAB supports these dependencies by providing parameters for dynamic behavior. Be sure to check out the Dynamic Sitemaps chapter.
# Special Element 'sitemap'
    [all sitemap elements]
# Element Types
Element Description
Text Renders an Item as text.
    • icon chooses the name of the icon file to show next to the element, more details.
  • When an Item is defined, you have the opportunity to assign a label and/or an icon at that point. If no label or icon are specified in the Sitemap, then the label and/or icon you assigned to the Item will be displayed. Setting a value for label or icon of a Sitemap element will override the values defined for the linked Item.
It has to be considered that if the label defined in a Channel or an Item contains text and state, these representations have to be overwritten separately in the Sitemap. In the following example a Item which has a label and state defined is overwritten.
    Frame label="Temperature" {
UoM = Units of Measurment
# Element Type 'Frame'
Frame [label="<labelname>"] [icon="<icon>"] {
    [additional sitemap elements]
    //# and so on...
# Element Type 'Default'
Default item=<itemname> [label="<labelname>"] [icon="<iconname>"]
# Element Type 'Text'
Text [item=<itemname>] [label="<labelname>"] [icon="<iconname>"]
Presents data as normal text. Most Item types can be used; the values can be prepared and reformatted by using string formatters and transformations. Please refer to the documentation on item labels for details.
Text item=Temperature label="Livingroom [%.1f °C]" icon="temperature"
# Element Type 'Group'
Group item=<itemname> [label="<labelname>"] [icon="<iconname>"]
# Element Type 'Switch'
Switch item=<itemname> [label="<labelname>"] [icon="<iconname>"] [mappings="<mapping definition>"]
  • mappings comes as an array of value-to-string translations, documented further down. Without the mappings parameter, user interfaces will present an On/Off Switch, if mappings are given, several labeled buttons will be rendered.
Switch item=LR_CeilingLight label="Ceiling Light" icon="light"
# Element Type 'Selection'
Selection item=<itemname> [label="<labelname>"] [icon="<iconname>"] [mappings="<mapping definition>"]
# Element Type 'Setpoint'
Setpoint item=<itemname> [label="<labelname>"] [icon="<iconname>"] minValue=<min value> maxValue=<max value> step=<step value>
# Element Type 'Slider'
Slider item=<itemname> [label="<labelname>"] [icon="<iconname>"] [sendFrequency="frequency"] [switchSupport] [minValue=<min value>] [maxValue=<max value>] [step=<step value>]
  • sendFrequency is used to distinguish between long and short button presses in the classic (web) frontend. This parameter defines the interval in milliseconds for sending increase/decrease requests.
    • Classic UI: If specified, a short press on the "up" or "down" button switches the item "on" or "off" (0 or 100) respectively.
    • Android app: If specified, a short press on the item row (except the slider itself) switches the item "on" or "off".
# Element Type 'Colorpicker'
Colorpicker item=<itemname> [label="<labelname>"] [icon="<iconname>"] [sendFrequency=<sendFrequency>]
This element is a combined control for something like a rgb or rgbw light where you can adjust brightness as well es the color hue. The down-button decreases brightness to zero and switches the light off. The up-button sets brightness to full but keeps the previous color (hue). The middle button opens an overlay to finetune your color. A color wheel let you pick the hue and a slider allows to set the brightness.
Colorpicker item=LR_LEDLight_Color label="LED Light Color" icon="colorwheel"
# Element Type 'Webview'
Webview item=<itemname> [label="<labelname>"] [icon="<iconname>"] url="<url>" [height=<heightvalue>]
# Element Type 'Mapview'
Mapview [item=<itemname>] [label="<labelname>"] [icon="<iconname>"] [height=<heightvalue>]
# Element Type 'Image'
Image [item=<itemname>] [icon="<iconname>"] url="<url of image>" [label="<labelname>"] [refresh=xxxx]
# Element Type 'Video'
Video [item=<itemname>] [icon="<iconname>"] url="<url of video to embed>" [encoding="<video encoding>"]
# Element Type 'Chart'
Chart [item=<itemname>] [icon="<iconname>"] [label="<labelname>"] [refresh=xxxx]
[period=xxxx] [service="<service>"] [begin=yyyyMMddHHmm] [end=yyyyMMddHHmm] [legend=true/false]
  • period is the scale of the time axis. Valid values are h, 4h, 8h, 12h, D, 2D, 3D, W, 2W, M, 2M, 4M or Y.
  • begin / end sets the beginning and end of the time axis. Valid values are in the format: yyyyMMddHHmm (yyyy = year, MM = month, dd = day, HH = hour (0-23), mm = minutes).
Visit Charts (opens new window) in the Wiki for examples.
# Mappings
Mapping syntax:
mappings=[value_1="description_1", value_2="description_2", ...]
# Dynamic Sitemaps
# Visibility
Visibility syntax:
visibility=[item_name operator value, item_name operator value, ... ]
  • equal to ==, unequal to !=
  • less than <, greater than >
Expressions are evaluated from left to right. The Item will be visible if any one of the comparisons is evaluated as true, otherwise it will be hidden.
Switch item=CinemaLight "Cinema light" visibility=[TV_Power==ON]
In the third example above, a control for a lawn sprinkler will be visible if it is Morning, OR if it is Afternoon, OR if the temperature is above 19 °C. Combining multiple conditions, for example Morning AND above 19 °C is not supported. To control visibility based upon combining multiple Items, or on more complex conditions, consider defining and using an additional intermediate Item that is set by a Rule. Rules have a rich set of features that can support more involved scenarios.
# Label and Value Colors
Colors can be used to emphasize an items label or its value based on conditions. Colors may be assigned to either the label or the value associated with an Item.
Label and Value Color Syntax:
labelcolor=[item_name operator value = "color", ... ]
valuecolor=[item_name operator value = "color", ... ]
The comparison operators for labelcolor and valuecolor are the same as for the visibility parameter.
Text item=Temperature labelcolor=[>0="blue"] valuecolor=[22="green"]
Text item=Temperature labelcolor=[>0="blue"] valuecolor=[==22="green"]
Text item=Temperature labelcolor=[>0="blue"] valuecolor=[Temperature==22="green"]
Note that expressions are evaluated from left to right; the first matching expression determines the color. If the order of the expressions was reversed, the color assignment would not work properly. Note also, the effect of omitting Temperature and the comparison operator in the expression 0="white" (as compared to ==0="white").
maroon
#800000
red
#ff0000
orange
#ffa500
olive
#808000
yellow
#ffff00
purple
#800080
fuchsia
#ff00ff
pink
#ffc0cb
white
#ffffff
lime
#00ff00
green
#008000
navy
#000080
blue
#0000ff
teal
#008080
aqua
#00ffff
black
#000000
silver
#c0c0c0
gray
#808080
gold
#ffd700
# Icons
openHAB allows a set of icons to be assigned to the different states of an Item and therefore to be presented in a Sitemap. Please refer to the documentation on Item configuration for details.
        Text item=Date
        Group item=Heating
Explanation:
