# VSCode
The following shows the steps for building a bundle using Visual Studio Code (VSCode). Please note that the instructions show a Win10 system but should be similar for OSX/Linux. This guide assumes you have a base development directory already defined (example: c:/users/me/development) and will reference that directory as %BASE%.
# One time setup
  1. Install Java Extension Pack for VSCode (https://marketplace.visualstudio.com/items?itemName=vscjava.vscode-java-pack (opens new window))
  2. Clone the addons (https://github.com/openhab/openhab-addons.git (opens new window) or preferably your own fork) to %BASE%\openhab-addons
  3. On Windows, VSCode should be configured to use powershell instead of the classic command line.
    If not configured already, add the following to the VSCode settings:
    "terminal.integrated.automationShell.windows": "C:\\Windows\\sysnative\\WindowsPowerShell\\v1.0\\powershell.exe"
    Either globally define the options via the global settings.json. You can also define them local to a specific bundle by putting those lines in the .vscode/settings.json file in the bundle (similar to tasks.json/launch.json below).
  4. If you want to setup openHAB code formatting guidelines, add the following to the VSCode settings:
    define .vscode
    Either globally define the formatting options via Files->Preferences->Settings->Extensions->Java configuration (or in the global settings.json). You can also define them local to a specific bundle by putting those lines in the .vscode/settings.json file in the bundle (similar to tasks.json/launch.json below).
Download settings.json (opens new window) for the recommended settings (or simply wish to copy the URLs in the above image).
# Steps for each Bundle
  1. Ensure the bundle builds correctly (natively with maven)
    1. Open console to the bundle location (example: %BASE%\openhab-addons\bundles\org.openhab.binding.russound)
    2. mvn clean install -DskipChecks in the console to build the bundle
    3. Should produce a jar file in the 'target' directory of the bundle(example: %BASE%\openhab-addons\bundles\org.openhab.binding.russound\target\org.openhab.binding.russound-3.1.0-SNAPSHOT.jar)
  2. Open VSCode and then open the folder of the bundle. From VSCode - use File->Open Folder->choose bundle directory (example: %BASE%\openhab-addons\bundles\org.openhab.binding.russound)
  3. Create a ".vscode" directory under the bundle (example: %BASE%\openhab-addons\bundles\org.openhab.binding.russound\.vscode)
    define .vscode
  4. Download tasks.json (opens new window) to the .vscode directory (example: %BASE%\openhab-addons\bundles\org.openhab.binding.russound\.vscode\tasks.json)
    define tasks.json
  5. Edit tasks.json and ...
    tasks.json changes
    1. Set openhab_* to the directories for your openHAB installation
    2. Set dist to the name of the JAR file maven is producing in the target directory
    3. Save and close tasks.json
  6. Stop any openHAB instance (if it's running).
  7. Start the openHAB instance with the debug option - start.bat debug from a console in the openHAB home directory. You should see the following line printed somewhere in the karaf console: Listening for transport dt_socket at address: xxxx (where xxxx should be 5005)
  8. Download launch.json (opens new window) to the .vscode directory (example: %BASE%\openhab-addons\bundles\org.openhab.binding.russound\.vscode\launch.json)
    define launch.json
  9. Edit launch.json and ...
    launch.json changes
    1. Set the port to xxxx (from step 7). This can be skipped if xxxx was 5005 from step 7.
    2. Set the hostName to the hostname running openHAB. This can be skipped if running locally (localhost)
    3. Save and close launch.json
  10. Verify that VSCode can build the system and connect to a debug instance of openHAB:
    1. Shutdown any instances of openHAB
    2. Press CTRL-SHIFT-P -> Tasks: Run Task -> Start openHAB (Debug) to start an openHAB instance in debug mode. You should see openHAB startup in a new VSCode terminal.
    3. Press F5 (or bring up debug in VSCode and choose the "Debug (Attach) - openHAB" configuration) and the following should occur in the VSCode terminal
      1. The maven compile occuring (successfully)
      2. The resulting JAR is copied to the openHAB addons directory (openhab_addons)
      3. Connecting to the openHAB instance (the debug call stack should show a bunch of openHAB type threads running)
# Notes
  1. May take openHAB a few seconds to realize there is a new bundle and to reinitilize it after it's been copied. Be a little bit patient.
  2. You must run the mvn Compile (Online) task atleast once to allow the offline compile to occur. You should use the mvn Compile (Offline) task for most of your development as it's quicker since it uses the cache files. When you are ready to commit (or release a test bundle) - you should run the mvn Compile (Release) task to include code checks (and resolve them).
  3. Win10+ allows forward slashes as part of its path. If you use backward slashes instead - you will need to double up on them since tasks.json uses a backward slash as a delimiter. Example: c:\\\\openhab
# Tasks
  1. Start openHAB (Debug) - this task will start a new instance of openHAB in debug mode (allowing VSCode to connect to it). Please shut down any other instances of openHAB prior to running this (see next task). This will open a new terminal for openHAB to run in. Formally, this will call start.bat debug (or start.sh debug on osx/linux) in the openhab_home directory.
  2. Stop openHAB - this task will stop any running instance. Please note this will stop an instance started outside of VSCode as well on the same machine. Formally, this will call stop.bat (or stop.sh on osx/linux) in the openhab_runtime/bin directory.
  3. mvn Compile (Online) - this task will run a online maven compile skipping code checks. Formally, will run mvn clean install -DskipChecks
  4. mvn Compile (Offline) - this task will run a offline maven compile skipping code checks (assumes you have run a online compile atleast once). Formally, will run mvn -o clean install -DskipChecks
  5. mvn Compile (Release) - this task will run a online maven compile with code checks. Formally, will run mvn clean install
  6. Copy Distribution to Addons - this task will run the 'mvn Compile (Offline)' task and then copy the resulting target file (as defined by dist) to your openHAB addons directory (defined by openhab_addons)
  7. Build - this is an alias for Copy Distribution to Addons task.
  8. Tail events.log - this will tail the events.log in a new terminal.
  9. Tail openhab.log - this will tail the openhab.log in a new terminal.
# Additional References
  1. VSCode with Java (opens new window)
  2. VSCode with Java debugging (opens new window)
