# openHAB Cloud Connector
# Features
- It serves as a connector to Google Cloud Messaging (GCM) and Apple Push Notifications (APN) for pushing notifications to mobile phone apps.
- It brings integration possibilities with services that require an OAuth2 authentication against a web server, such as IFTTT or Amazon Alexa Skills.
# Installation via UI
- Open the openHAB web portal and login as an administrator.
- Click on Settings, followed by Misc (in the Add-ons section)
- Using the + button on the bottom right you can install the openHAB Cloud Add-on
# UUID and Secret
To authenticate with the openHAB Cloud service the add-on generates two values when the add-on is installed. These values need to be entered in your account settings of the openHAB Cloud service. The first one is a unique identifier, which allows to identify your runtime. One can think of it as something similar like a username for the cloud authentication. The second one is a random secret key which serves as a password. Both values are written to the local file system. If you loose these files for some reason, openHAB will automatically generate new ones. You will then have to reconfigure UUID and secret in the openHAB Cloud service under the My account section.
Location of UUID and Secret:
| File | Regular Installation | APT Installation |
| UUID | userdata/uuid | /var/lib/openhab/uuid |
| Secret | userdata/openhabcloud/secret | /var/lib/openhab/openhabcloud/secret |
After installing this add-on, you will find configuration options in the openHAB portal under Settings -> Other Services -> openHAB Cloud:
Please note, that you should not expose all your items in this settings dialog. Also note that at present this feature is currently turned off. You just need to expose those items, which you want to be accessible by IFTTT. This setting has no affect on Alexa or Google Assistant functionality.
Alternatively, you can configure the settings in the file conf/services/openhabcloud.cfg:
############################## openHAB Cloud Connector #############################
# (https://myopenhab.org/)
#baseURL=
# Possible values are:
#mode=
#expose=
Note: The exposed items will show up after they receive an update to their state.
Note: In order to use an openHAB UI via the Cloud Connector exposing items is not neccessary. Administrative actions are limited to creating things, items and rules, deleting them is inhibited via the Cloud Connector.
