# Layout Pages
Layout Pages are used in the main web user interface to display widgets in an organized manner. You can choose among several layouts, based on whether you want to control the layout completely, or let the container decide where to place the widgets.
Layout Page Example
# Anatomy of a Layout Page
A layout page can host one or multiple blocks, optionally followed by a masonry layout.
In a row, you may add columns which will spread across the row, possibly wrapping their contents to another row (but still within the same oh-grid-row). Each column can host one widget from the standard standalone widget library, or a personal one.
When you're designing a layout page, it's important to remember how this page will be used. Sometimes, it will be on a phone, and other times on a bigger screen.
Column Options
Property Minimum screen width Examples of devices
width No minimum, default All devices including phones
xsmall >= 480px Smartphones in landscape mode
small >= 568px Smaller tablets (Nexus 7...) in portrait mode
medium >= 768px Most tablets in portrait mode
large >= 1024px Smaller/regular tablets (iPad, iPad Mini...) in landscape mode*
xlarge >= 1200px High-end tablets (iPad Pro...), desktops
* Note that the sidebar will potentially be displayed and has a width of 260px
If you don't specify any width or breakpoints, the column will spread evenly on the row, without wrapping. This is fine for a couple of columns and simple widgets only, since on a small smartphone screen, you will rapidly get out of room. That's why you may find yourself wanting to let a column be 100% by default, so that it occupies the entire screen, and then reduce the width for medium or large breakpoints.
  label: Overview
blocks:
  - component: oh-block
    config: {}
        - component: oh-grid-row
          config: {}
              - component: oh-grid-col
                  width: "100"
                  small: "50"
                  medium: "33"
                  default: []
                  width: "100"
                  small: "50"
                  medium: "33"
                  default: []
                  width: "100"
                  medium: "33"
                  default: []
Responsive Layout
# How to Build a Layout Page
# Defining the Layout
When you create a new Layout Page, you'll notice the 2 buttons Add Block and Add Masonry. Clicking either will add the respective container to the page. If you have multiple blocks, you can use the black context button (or the Code view) to reorder them with the Move Up/Move Down menu options. You can also copy it and paste it as another block after they've been designed, if you wish to have multiple similar blocks. You can also give a title to the block which will be displayed above it.
Blocks are also good candidates to use the conditional visibility features on, with the visible and visibleTo properties. You can restrict what's displayed on the page based on an expression, or who is currently viewing the page. In Design mode, you will not be able to see the effect of these properties, notably visible, but in Run mode they will be taken into account.
# Adding Widgets
  • for columns or masonry, the default standalone widget;
  • for items inside list cards, the default list item widget;
  • for cell containers, the default cell widget.
Add from Model
REMARK
